Not pulling when get warm
17,000 MILES • AUTOMATIC
LEOPOLD2019
After a drive through water one day, My car listed above w203 does not want to pull after a 70 km drive, unless it cools downs first. please assist.
Dec 11, 2019 at 1:20 AM
  • 55,636 POSTS
What happens is the catalytic converter is super hot then when you go through water it cools it and can break apart the material inside. To confirm the issue here is a guide to help us:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
We should try to get the codes as well.
Dec 12, 2019 at 7:18 AM
LEOPOLD2019
Hello Ken, That problem also led to the check engine light to turn on.
Dec 26, 2019 at 7:57 PM
  • 55,636 POSTS
That's good. it will tell us what's going on. please run the codes and get back to me.
Dec 30, 2019 at 9:02 AM
