Not move in a gear
108,000 MILES • 4.4L • V8 • 2WD • AUTOMATIC
EDVARD EDVA
Hi, my friend and I just picked up a 840ci. seller said there is automatic gearbox problem. What was wrong:
You could start the car, put car in any gear you want, but car would not move. the revs was maximum of 2200 does not go any more. When car on "park" and you accelerate, car tries to move but it feels like you hold brakes and trying to accelerate while car on "drive", but that is actually on "park"
Next:
We bought gearbox the same as was in there 5hp30.
gearbox done only 86,000 miles.
We replaced old to the one we bought and car was running good for about twenty miles. then I felt like it was hard for car to drive, and would not rev over 2200.
I drived it home, stoped next to home, tried to reverse to park it and car not moved no more.
what we think happened:
the oil pipes from gearbox to car are blocked and oil not circulating and not cooling, gearbox overheated and gone.
Any advice?
What we need to check?
Or anything we need to do?
Any help appreciated.
Thanks a lot.
Dec 23, 2017 at 3:55 AM
  • 31,937 POSTS
The transmission will have an external oil cooler either in the radiator or a stand alone unit, often when transmissions fail these coolers block with debris, they should be replaced as a standard procedure. if the cooler has been blocked the transmission can over heat and do serious damage. i would start by dropping the pan and inspecting for burnt oil and debris in the pan.
Dec 25, 2017 at 3:39 PM
