Not going past 20 high RPMs slow going, not accelerating properly?
2002 HYUNDAI ELANTRA
129 MILES • 2.7L • V6
KNOX24
Runs well but when I punch on the gas pedal slow going really slow.
Oct 30, 2023 at 6:54 PM
STEVE W.
  • 15,357 POSTS
That sounds like the transmission is slipping. If it's a manual that is indicative of a worn or failing clutch disc. In an automatic it generally means that it has an internal problem, either a pressure loss in the fluid or the clutch plates in its geartrain are worn or glazed.
So which transmission type do you have?
Oct 30, 2023 at 11:09 PM
