Not getting up to temperature
175,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DAVIDMKINCADE
  • 8 POSTS
Truck having a hard time getting to temperature only getting to about 170 heat blows lukewarm air . Once in a while my coolant light comes on and I add about maybe a cup of antifreeze.
Oct 24, 2017 at 8:12 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Has someone removed your thermostat?
If not, have you tried a new thermostat?
Oct 25, 2017 at 12:43 AM
DAVIDMKINCADE
  • 8 POSTS
Not sure if it has been removed. I will try and install a new one this weekend . Thanks for the quick reply . Will let you know next week.
Oct 25, 2017 at 1:53 AM
  • 55,766 POSTS
Here is a guide to help you see what you are in for when doing the job:
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Cheers, Ken
Oct 25, 2017 at 1:13 PM
DAVIDMKINCADE
  • 8 POSTS
Thank you this should help a lot.
Oct 27, 2017 at 6:51 AM
DAVIDMKINCADE
  • 8 POSTS
Ok got new thermostat in getting up to temp but still blowing Luke warm air . Any suggestions?
Nov 5, 2017 at 2:18 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
feel both heater hoses going into the firewall under the hood to the heater core, they should both be hot once the engine is up to temp, if one is hot and the other luke warm, then your heater core is clogged. If so, you could try a backflush before having to replace the heater core.
If both hoses are just luke warm, check to see if there is a heater control valve on either heater hose that might be stuck closed, so if it has a heater control valve, check both the heater hose before and after that valve, they should both be hot.
Nov 5, 2017 at 3:12 AM
DAVIDMKINCADE
  • 8 POSTS
I've been playing around and found that the temp does not change when moving from cold to hot .found blend door motor and it moves maybe a 1/8 of an in when moving dial
Nov 5, 2017 at 3:22 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That has got to be the problem then. I suspect both heater hoses were hot then.
Nov 5, 2017 at 4:10 AM
DAVIDMKINCADE
  • 8 POSTS
Yes they were .
Nov 5, 2017 at 4:12 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I think you found the problem.
Nov 5, 2017 at 4:17 AM
DAVIDMKINCADE
  • 8 POSTS
Thanks to everyone for the help
Nov 5, 2017 at 5:16 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome...
Nov 5, 2017 at 5:22 AM
