Not getting gear O/D lights on and off.
2007 DAIHATSU SIRION
100,010 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
MATLAB
O/D lights is on and off and is still on when driving. then the car bucks when it gets in to gear and it stays like this even if going uphill when gear should be shifting into somthing else it stays stuck into this gear and stays stuck. i was trying to install a muffler to refine the engine sound. i had to touch only 1 senso that is on the air filter to install this muffler.
Dec 22, 2013 at 6:15 PM
  • 110,241 POSTS
Have the computer scanned to identify transmission trouble codes.
Dec 24, 2013 at 2:26 AM
MATLAB
fortunately we id the problem, it was a broken pin on the gear box sensor plug, it was corroded and thus not giving the correct electrical signal. now all is good after replacement.
thank you.
Dec 25, 2013 at 12:40 PM
  • 110,241 POSTS
Glad you got it fixed. Take care.
Dec 26, 2013 at 5:36 AM
