What you're describing is not a carburetor. Its called throttle body injection. The wires run to the injectors. (This was an early for of fuel injection that some manufacturers used).
Check your engine for a vacuum leak at one of the vacuum hoses.
Also switch the fuel pump relay with another identical relay (you'll find another on in the same fuse box). If that cures the problem then you know that the original fuel pressure relay was bad.
Could the fuel in the tank have gone bad by sitting there for many months?
Saturday, August 2nd, 2014 AT 7:30 PM
