not getting fuel
200,000 MILES
MARKTHEMADMAN
Fuel pump is working. Got gas going to the throttle body. Have power going to both injectors. And I have plenty of fuel pressure. I have clean the throttle body and the injectors but I'm not getting any gas to the engine. I think its electrical. what all do I need to check to get gas going
May 26, 2013 at 9:42 AM
HMAC300
  • 48,601 POSTS
check pressure first should be 9-11 psi . if no pressure see if power it going to pump or take gas cap off and listen to hear pump when key turned on. check fuses and relay behind glove box.
May 26, 2013 at 11:08 PM
