I am getting fire to my crank shaft position sensor ignition module and coil, but I am not getting fire out of the distributor to spark plug.
Aug 5, 2016 at 6:05 AM
HMAC300
✓Experienced Mechanic
if you get fire to the distributor then it is either a bad rotor or distributor cap so check those.
Aug 5, 2016 at 6:16 AM
DAVID WARWICK
MEMBER
Brand new cap and rotor.
Aug 5, 2016 at 6:23 AM
RIVERMIKERAT
Pull the coil wire and stick a well-insulated screwdriver in the end. Hold it about half an inch or so from a ground as someone cranks the engine. No spark=bad coil or wire. Check it with a known good one.
