not enough heat from vents?
111,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Battery was low but I started the car and had it charged, but the heat from vents when I turn heat on is not really really hot, it is warm, but not where I think should be. Only code I saw was for intake air leak which I doubt has anything to do with it.Coolant was a bit below minimum so I added some and topped it off
Dec 30, 2025 at 6:17 AM
  • 55,721 POSTS
It sounds like the heater core is clogged or the coolant is low which will cause this problem as well, here is a video to go over which can help you fix it or get us started on what the problem is not. Please go over it and get back to me.
https://www.youtube.com/watch?v=SNRb6pSwYuU
Please go over this guide and get back to us.
Dec 31, 2025 at 1:28 AM
