Not developing pressure in cooling system
210,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
MIKE GRAHAM2
I can drive this thing all day and it never develops any pressure.
I figured the head gasket was bad(It was) and I replaced it and put a new head on as well.
No leaks, oil and coolant are not in each other.
I had to drive it onto a hill to 'burp the system, as it had a bubble in heater core.
Heat is now working, but still no pressure.
Pump is moving fluid, new thermostat.no leaks.
Feb 9, 2019 at 2:24 AM
  • 110,248 POSTS
Have you replaced the radiator cap? If it isn't holding pressure, this will be the result.
Also, see if you can pressurize the system to see if it builds and holds pressure. If it doesn't there is a leak. If it does, I suspect the radiator cap.
Here is a link showing how to pressurize test the system:
https://www.2carpros.com/articles/radiator-pressure-test
Feb 9, 2019 at 11:42 AM
