My car was just fine 40 minutes ago. I went to start again, and the lights came on, but it is not cranking.
Jan 15, 2025 at 8:03 AM
✓Experienced Mechanic
It sounds like the starter motor has gone bad, but can I ask if the engine will crank in neutral? Also, please go over this video which can help you fix it:
I would check the fuse #f27 in the smart junction box on the left side of the dash and fuse #f41 in the fuse panel under the hood. Here is a guide to help you:
