It won't start, horn blows, radio still come on?
100,000 MILES • 4WD • AUTOMATIC
LOU20
  • 88 POSTS
My car stopped on me while driving on the highway. It won't start, horn blows, radio still come on. Got battery tested and it was still good.
May 8, 2026 at 6:04 AM
  • 55,770 POSTS
So does the engine crank over and not run? or does the engine not crank over? Also, does the car have gas in it? Sometimes the gas gauge can break not telling you the car is out of gas. It sounds like the crankshaft sensor went bad or the fuel pump has gone out. Please go over this video so I can help you fix it.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Please go over this guide and get back to us.
May 10, 2026 at 10:30 AM
LOU20
  • 88 POSTS
When I try to crank it whines. Yes I had gas in the car. Soon it stopped the battery light and some other symbols came on the dashboard.
May 10, 2026 at 10:36 PM
  • 55,770 POSTS
Yep, this is a sign the battery is no good or the engine is locked up, I can tell for sure if you send me a video of the engine when you try to crank it over. Also you can take the battery down to the auto part store where they will test it for you for free.
May 11, 2026 at 9:19 AM
LOU20
  • 88 POSTS
Had the battery tested it was good. The car is currently at the repair shop.
May 13, 2026 at 8:20 AM
LOU20
  • 88 POSTS
Found out that the timing belt had snapped.
May 13, 2026 at 11:16 PM
  • 55,770 POSTS
I video of the engine cranking would have told me that, thanks for letting us know. Please use 2CarPros anytime we are here to help.
May 14, 2026 at 8:29 AM
