Running like a charm cranks up an goes about ten miles an shuts off and it cranked but when you put in it drive cuts back off.
Oct 17, 2018 at 12:56 PM
✓Experienced Mechanic
This sounds like a fuel pump or a crankshaft angle sensor is bad. When it will not run can you hear the fuel pump in the tank going? Here is a guide to help us get started:
