Not cranking
150,000 MILES • 0.5L • 6 CYL • AUTOMATIC
SHERRYDANCE
Running like a charm cranks up an goes about ten miles an shuts off and it cranked but when you put in it drive cuts back off.
Oct 17, 2018 at 12:56 PM
  • 55,746 POSTS
This sounds like a fuel pump or a crankshaft angle sensor is bad. When it will not run can you hear the fuel pump in the tank going? Here is a guide to help us get started:
Cheers, Ken
Oct 18, 2018 at 12:25 PM
