Not charging
193,000 MILES • 6.0L • V8 • TURBO • 4WD • AUTOMATIC
6.0JOED
  • 5 POSTS
My batteries were draining overnight so I found that if I unplugged the pigtail on the alternator it was fine. I would just plug it back in when running. I bought a new alternator and installed it and when I plugged the pigtail in it hummed. So I am sending that one back and got a replacement from AutoZone ( alternator was lifetime) when I installed the new one I have nothing. No battery light on the cluster (cluster was rebuilt and I tried another and changed bulb) and when I test the lug on the back of the alternator I have only battery voltage. Yes I am waiting a couple minutes for glow plugs to go off. I also put the one that I ordered back on and it charges but hums key off. Any help would be appreciated. thanks
Nov 24, 2019 at 5:27 AM
Good evening,
There should be 2 wires with battery voltage. The red and orange wires should have voltage all the time.
I attached a diagram for you to view. Let me know which one is not hot.
Nov 24, 2019 at 10:10 AM
6.0JOED
  • 5 POSTS
The wire with the fusible link has power all the time as it goes to the batteries. The other wire gets power when I start the truck.
Nov 25, 2019 at 5:02 AM
6.0JOED
  • 5 POSTS
I have constant power to the wire on the pigtail and when I start the truck I get voltage to the the other wire on the pigtail (the one that goes to the cluster).
Nov 25, 2019 at 5:09 AM
The orange wire should have power all the time. The red wire should have power all the time as well.
Nov 25, 2019 at 5:10 AM
6.0JOED
  • 5 POSTS
Correct but the alternators don’t charge. I have two different alternators that I have tried. They have both been tested by three different shops.
Nov 27, 2019 at 12:58 AM
The orange wire is powered externally. It has nothing to do with the alternator itself. It comes from the battery through the fusible links as in the diagram I sent you. When that wire gets voltage, the alternator will work.
Nov 27, 2019 at 3:22 AM
6.0JOED
  • 5 POSTS
The orange wire with blue tracer also has a fuse able link directly to the battery and has power all the time.
Nov 27, 2019 at 3:30 AM
Okay, so the orange/blue and the red have power with the truck off?
What about the green/red wire?
Nov 27, 2019 at 3:32 AM
