Not a problem - just a question
36,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
MUSICOLLECTOR
  • 15 POSTS
Thank you for your kindness in offering free advice. No repair involved here - just advice. :-)
I have a 1999 Honda Accord with 36,000 miles and I baby it. It has a 2.3 L V-Tech engine. I feel nervous when the tachometer goes above 2000 rpm, though I rarely go above 3000. Is it bad for the engine to go over 2000 RPM? Am I wasting gas in the 2000 to 3000 RPM range? Are these engines designed to go to 3000?
Apr 12, 2015 at 12:09 PM
  • 110,251 POSTS
No, you aren't hurting anything. These engines can go much higher without damage. All cars have what is called a RED LINE. That is the danger point that can cause engine failure. On your tachometer, is there anything near the 6K RPM area that is red?
Apr 12, 2015 at 12:35 PM
MUSICOLLECTOR
  • 15 POSTS
Thanks for your quick response.
Yes, the red zone is from 6250 to 8000 RPM.
Regards.
Harry
Apr 13, 2015 at 3:48 AM
  • 110,251 POSTS
That is the danger zone. If you are below that, everything should be just fine.
Apr 13, 2015 at 11:08 AM
MUSICOLLECTOR
  • 15 POSTS
I have added your website to my resources page
Harry
Apr 13, 2015 at 1:55 PM
  • 110,251 POSTS
Thanks, Harry. Have a good day.
Apr 13, 2015 at 9:43 PM
MUSICOLLECTOR
  • 15 POSTS
Thanks so much for the tee-shirt. I really appreciate it. However, Medium is very tight for me. I should have specified Large, but I always use Medium. Looks as if this supplier's Medium is really Small. :)
Aaah, it is the thought that counts. THANK YOU!
Many regards,
Harry
May 4, 2015 at 11:19 AM
  • 110,251 POSTS
Harry:
Give them a call. I'm sure they will get you one that fits.
May 6, 2015 at 11:54 AM
MUSICOLLECTOR
  • 15 POSTS
Thanks very much. I will do that. I really appreciate it. I look forward to wearing it.
Harry
May 6, 2015 at 1:28 PM
THIS IS MIKE
  • 686 POSTS
I will get you one that fits :)
Have a great day.
May 8, 2015 at 3:24 AM
MUSICOLLECTOR
  • 15 POSTS
Thanks kindly.
Harry
May 8, 2015 at 5:23 AM
