Okay, it most likely is just listed as the 4.6 motor which is a Northstar engine.
176 for compression is great number. 180 was when it was new. The car is fifteen years old and there is some wear in the motor so a reading of compression a little under spec is good.
That is not an issue at this point. Is there some other issue that concerns you?
May 29, 2018 at 6:23 AM
