HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Electrical
Ignition Switch
Key
SPONSORED LINKS
No power on CPS or CSS with key on
KENNETH CHURCH
MEMBER
2003 FORD F-150
4.6L
V8
2WD
AUTOMATIC
230,000 MILES
Should there be power with key on?
Tuesday, October 1st, 2019 AT 9:52 PM
BMDOUBLE
MECHANIC
Pardon if I ask what CPS and CSS are? I've been a Ford dealer tech since 1992 and haven't heard of these acronyms.
SPONSORED LINKS
Wednesday, October 2nd, 2019 AT 9:32 AM
KENNETH CHURCH
MEMBER
Crank shaft sensor, cam shaft sensor.
Thursday, October 3rd, 2019 AT 12:12 PM
BMDOUBLE
MECHANIC
No sir, they are variable reluctance sensors, meaning that they generate 0-1 volt signal when the engine is cranking or running only.
Thursday, October 3rd, 2019 AT 1:33 PM
Please
login
or
register
to post a reply.
Related Ignition Switch Key Content
My Fan For Heat/def Comes On While The Key Is In My...
My Fan For Heat/def Comes On While The Key Is In My Pocket, Sometimes Its On When I Get Up In The Morning Draining The Battery.
Asked by
Anonymous
1 ANSWER
2003
FORD F-150
1991 Ford F150 Key Start
I Put My Key In The Slot And The Mechanism Want All The Way Around And Would Not Engage The Starter. The Radio And Accessories Lights Came...
Asked by
mrddoyle
1 ANSWER
1991
FORD F-150
1987 Ford F150 Ignition Switch
Hi I Just Replaced The Cylenoid Switch In My Truck But When I Go To Start It It Will Turn Over But When I Take The Key Out Of The Ignition...
Asked by
thelongroad1
1987
FORD F-150
Lost Keys
I Lost Both My Keys To My Truck, I Have Called Ford And They Dont Make New Keys For Cars 10 Years Or Older. I Was Just Wondering If I Could...
Asked by
fordguy11
1 ANSWER
3 IMAGES
2001
FORD F-150
Lost Key
Lost The Key To My 95 F150 Any Way To Remove Ignition Without Screwing The Column Up?
Asked by
Gary Picard
1995
FORD F-150
VIEW MORE
SPONSORED LINKS
Battery Replacement
Battery Replacement Saturn
How to Replace Battery
Online car repair manuals
