Non working gauges
141,774 MILES • 2.0L • 3 CYL • MANUAL
IRMA MOORE
None of my gauges work. The airbag light is the only thing on.
Feb 12, 2018 at 5:02 AM
  • 55,743 POSTS
I sounds like you popped a fuse # 7, 11 or 9. Here is a guide to help you test the fuse and the fuse locations so you can find them:
Check out the diagrams (below).
Cheers, Ken
Feb 13, 2018 at 10:19 AM
IRMA MOORE
That didn't work. Was told might be the computer to the car.
Feb 14, 2018 at 4:05 AM
  • 55,743 POSTS
It could be the cluster which is highly possible if all the fuses are good, did you check them?
Feb 14, 2018 at 4:06 AM
IRMA MOORE
Yes.. i think it something else.. on my way home i lost my gears. Had to drive home in 3.
Feb 14, 2018 at 2:19 PM
  • 55,743 POSTS
I have heard of this before and it ended up being the ignition switch but to confirm we should test through it. Here is guide and the wiring diagrams to help
Cheers, Ken
Feb 15, 2018 at 2:38 AM
