No, you will get a spark with a bad crank sensor. What you will not get is fuel injector pulses. Check your fuses in the under hood junction block. In particular, check the ones labeled ECM, PCM, IGN, or INJ. If you can get your hands on a scanner, check it for codes.
Try spraying starting fluid into the air intake again. Spray a lot of it though. Then crank it. Try it a few times too.
Finally, if I had to guess, I would replace the crank sensor. But again, that is only if I had to guess, and I do not like guessing at all.
Mar 17, 2018 at 8:59 PM
