When i switch on AC the radiator cooling fan runs smoothly, but after a while it becomes noisy.
Oct 20, 2017 at 9:49 PM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
Perhaps the bearing/bushing is going bad.
Oct 20, 2017 at 11:39 PM
PLC MAN
MEMBER
Okay thanks. I will check it and give you a feedback.
Oct 21, 2017 at 4:03 AM
This will be a sealed motor, best option is to replace the fan motor. they do not usually give much of a problem, so a used unit from a wrecker should be fine.
