Noisy Alternator
140,000 MILES • 4 CYL • TURBO • AUTOMATIC
DRKTURKEY
What are reasons for whistling noise from the alternator?
Feb 9, 2016 at 3:40 AM
HMAC300
  • 48,601 POSTS
a bearing going bad will do that Ican't think of much else unless the fan at front is moving a ton of air.
Feb 9, 2016 at 4:05 AM
DRKTURKEY
Many thanks for your prompt response. I have already tightened the belt. Is the solution to replace the alternator?
Feb 9, 2016 at 4:08 AM
HMAC300
  • 48,601 POSTS
normally yes
Feb 9, 2016 at 4:34 AM
HMAC300
  • 48,601 POSTS
but disconnect the belt and see if noise stops
DRKTURKEY
Many thanks again!
Feb 9, 2016 at 4:36 AM
