Noise when turning
200,000 MILES • 1.5L • 4 CYL • MANUAL
MARIOC68
  • 120 POSTS
Hi, the power steering produces a noise just like the belt skids, this does when you turn the belt on both sides.
Comment that the inner pump assembly (ring, rotor, o-ring).
Apr 6, 2017 at 10:38 PM
HMAC300
  • 48,601 POSTS
belt normal life is 60,000 miles including tension-er for replacement that may be the problem. if any oil on pulleys etc. must be cleaned off because it destroys a belt. this includes WD-40 that people like to spray on things. any oil leak must be repaired.
Apr 6, 2017 at 11:51 PM
