Noise when turning
MARIOC68
  • 1995 TOYOTA COROLLA
  • 1.5L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
Hi, the power steering produces a noise just like the belt skids, this does when you turn the belt on both sides.
Comment that the inner pump assembly (ring, rotor, o-ring).
Friday, April 7th, 2017 AT 5:38 AM
HMAC300
  • 48,601 POSTS
Belt normal life is 60,000 miles including tension-er for replacement that may be the problem. If any oil on pulleys etc. Must be cleaned off because it destroys a belt. This includes WD-40 that people like to spray on things. Any oil leak must be repaired.
Friday, April 7th, 2017 AT 6:51 AM
