Noise when starting up and check engine light turns on
86,500 MILES • 3.8L • V6 • 4WD • AUTOMATIC
MARCPONDER
when I start it in the morning it starts fine with no noise. If I turn it off for a few minutes after driving then restart it sounds like a tractor/diesel starting up.
Check engine light comes on.
Feb 10, 2020 at 4:53 AM
Good afternoon,
Can you upload a video of the noise so I can hear it?
Feb 10, 2020 at 5:00 AM
MARCPONDER
Here you go.
Feb 10, 2020 at 6:03 AM
Thanks.
That is an internal engine noise and is not good.
It sounds like a main or rod bearing. They quiet down when the oil pressure builds up.
I would have the oil pressure tested to be sure it is not the oil pump.
Do not wait on this. That noise could get worse and leave you down.
Feb 10, 2020 at 6:25 AM
