noise uphill
105,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CARDO
I have a problem with my wk 2005 3.7. Lately I can hear a noise coming from the rear end I don't know where exactly the sound is coming from, it sounds like the exhaust is loose, but I checked the exhaust and it is very tight and fixed. The noise happens only when accelerating uphill after a short time.
any idea?
Mar 17, 2016 at 5:21 AM
MIKE H R
  • 3,094 POSTS
check the bolts holding the rear end on and the transmission mount. It may shift a little when put under stress.
Mar 17, 2016 at 6:33 AM
CARDO
i will check this , weird thing is the noise does not come directly after a short time climbing up maybe something when it heat it start the noise .
are you sure it doesn't related to transfer case differential ??.
Mar 18, 2016 at 10:17 AM
  • 55,781 POSTS
This noise could be a U joint, please inspect for rust around the joint to confirm, you may also remove the drive shaft and test the mobility of the joint as well.
Mar 19, 2016 at 12:17 AM
CARDO
hi
a get a mechanical to look at the problem he said that there's right rear axe that hold the transfer case is bad and need replacement
i didnt fix it yet waiting to see another opinion .
Apr 6, 2016 at 2:15 AM
MIKE H R
  • 3,094 POSTS
Get the rear end up in the air with wheels off the ground check the rear axle by moving each wheel back and forth and in and out , if there is too much play or give it could be the rear axle bearing
Apr 6, 2016 at 3:59 AM
