Not going into park is likely a linkage related issue. Do the other gear selections work as designed?
As far as the noise, it could be coming from worn brake pads, a faulty axle bearing, or even a bent or rusted dust cover behind the brake rotor.
When you hear the noise, does it seem to make a clicking sound? When driving straight, do you notice any noise?
I attached the directions for adjusting the shift cable below. Take a look through it and let me know if you are comfortable performing them. Also, take a look through this link and let me know if anything mirrors what you see/hear:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Images (Click to enlarge)
May 19, 2024 at 12:57 PM
