I can hear this noise coming from the brakes
50,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
PAPET
  • 105 POSTS
Every time I slow down and apply the brakes, I can hear this noise coming from the brakes. And after applying the parking brake, I can hear this noise too. It is like a squeaking noise that something is touching each other. Thanks and hoping for your most appreciated reply.
Sep 15, 2017 at 3:33 AM
CARADIODOC
  • 34,391 POSTS
If you also hear it while the van is moving, the additional cause is the pads are low this video can help you replace the front brakes.
https://youtu.be/SD9-MLW6Yts
Sep 15, 2017 at 9:54 AM
PAPET
  • 105 POSTS
I want to tell you were correct! Thanks and hoping for your most appreciated reply.
Sep 18, 2017 at 2:49 AM
