Noise in front end
246,600 MILES • 5.0L • V8 • 2WD
CARLA REED
  • 27 POSTS
Daughter has notice a roaring/thump in front passenger side. It's not real loud. Do you have any suggestions? Thank you.
Jan 2, 2019 at 7:18 AM
Good evening,
Check the stabilizer link kits. they are bolts that contain bushings. they need to be checked to see if they have broken.
https://www.2carpros.com/articles/popping-noise
Some other possibilities
1. Front strut or mount.
2. Control arm bushings worn out whether upper or lower.
3. Ball joints. excessive play up and down or laterally.
4. Loose wheel.
5. Brakes. the caliper pins missing or worn.
All these need to be checked to see what is causing the noise. most shops will do a free suspension check for you.
Jan 2, 2019 at 9:28 AM
CARLA REED
  • 27 POSTS
Thank you for responding so quickly. I will definitely pass your info to her. Thanks again
Jan 2, 2019 at 12:04 PM
You are welcome.
Always glad to help.
Jan 2, 2019 at 8:36 PM
