Noise in front end
CARLA REED
  • 1999 FORD EXPLORER
  • 5.0L
  • V8
  • 246,600 MILES
Daughter has notice a roaring/thump in front passenger side. It's not real loud. Do you have any suggestions? Thank you.
Wednesday, January 2nd, 2019 AT 3:18 PM
  • 52,797 POSTS
Good evening,
Check the stabilizer link kits. they are bolts that contain bushings. they need to be checked to see if they have broken.
https://www.2carpros.com/articles/popping-noise
Some other possibilities
1. Front strut or mount.
2. Control arm bushings worn out whether upper or lower.
3. Ball joints. excessive play up and down or laterally.
4. Loose wheel.
5. Brakes. the caliper pins missing or worn.
All these need to be checked to see what is causing the noise. most shops will do a free suspension check for you.
Wednesday, January 2nd, 2019 AT 5:28 PM
CARLA REED
  • 27 POSTS
Thank you for responding so quickly. I will definitely pass your info to her. Thanks again
Wednesday, January 2nd, 2019 AT 8:04 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Thursday, January 3rd, 2019 AT 4:36 AM
