Noise from the engine
112,867 MILES • 4 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the vehicle engine do produce noise for some seconds when started in the morning or whenever the vehicle is cooled. I knew that the problem is that the oil pump is not pumping as early as possible cause friction to occur in the moving parts. I have changed the engine oil and filter the problem still persist. How can it be fixed?
Sep 18, 2020 at 4:54 PM
Good morning,
Can you upload a video of the noise so I can hear if it is lifters on the top end or bearings on the lower end of the car.
Good chance it is the pump as the internal check valve may be bleeding off and draining the oil passage of all oil.
Worse case scenario is that the main and rod bearings may have too much play causing the noise.
NOTICE:
Do not remove the oil pump or oil pump relief valve from the timing chain cover sub-assembly.
Remove engine and trans-axle
Remove the engine and trans-axle . [ 2ar-fe engine mechanical: engine assembly: removal ]
Remove engine wire
Remove ignition coil assembly [ 2ar-fe ignition: ignition coil and spark plug: removal+ ]
Remove cylinder head cover sub-assembly [ 2ar-fe engine mechanical: engine unit: disassembly+ ]
Remove crankshaft position sensor [ 2ar-fe engine control system: crankshaft position sensor: removal+ ]
Remove crankshaft pulley [ 2ar-fe engine mechanical: engine unit: disassembly+ ]
Remove no. 2 timing chain cover
Remove the 2 bolts and no. 2 timing chain cover.
Remove engine mounting bracket rh
Remove the 5 bolts and engine mounting bracket rh.
Remove v-ribbed belt tensioner assembly (for compressor and generator) [ 2ar-fe engine mechanical: engine unit: disassembly+ ]
Remove v-ribbed belt tensioner assembly (for vane pump) [ 2ar-fe engine mechanical: engine assembly: removal+ ]
Remove timing chain cover sub-assembly
Remove the 17 bolts and 2 nuts.
Remove the timing chain cover by prying between the timing chain cover and cylinder head, camshaft housing, cylinder block and stiffening crankcase with a screwdriver as shown in the illustration.
NOTICE:
Be careful not to damage the contact surfaces of the cylinder head, camshaft housing, cylinder block, stiffening crankcase or chain cover.
HINT:
Tape the screwdriver tip before use.
Remove the 3 gaskets from the stiffening crankcase.
REMOVE TIMING CHAIN COVER OIL SEAL
Using a screwdriver and wooden block, pry out the oil seal.
NOTICE:
Do not damage the surface of the oil seal press fit hole.
HINT:
Sep 18, 2020 at 9:56 PM
BLESSING EWOBOR
  • 753 POSTS
Sep 18, 2020 at 10:49 PM
You are welcome.
Always glad to help.
Sep 18, 2020 at 10:55 PM
