There is a ticking noise and whistle noise from engine?
50,000 MILES • 3.6L • V6 • AUTOMATIC
SKOOTER28
  • 98 POSTS
I hear a ticking noise and whistle noise from engine. I’ve replaced the idler pully, the tensioner pully, and belt and still hear this whistle noise. Also the water pump has been replaced.
Apr 19, 2025 at 1:11 PM
  • 55,746 POSTS
It sounds like the A/C compressor is going bad but do me a favor and remove the serpentine belt and start the engine for a second to see if the noise is gone, that way we can see if the noise is accessory related. Also, is there any discoloration at the A/C compressor pulley? If so, this is a sign the compressor is going bad. You might want to try turning the HVAC system off to see if anything changes.
Apr 21, 2025 at 3:48 AM
SKOOTER28
  • 98 POSTS
I think you're right cause the water pump went bad, and my gf thought the A/C compressor was making the noise the whole time. What about that ticking, is that normal?
Apr 21, 2025 at 5:02 AM
  • 55,746 POSTS
Yep, that is what it sounds like, the ticking is not normal. Can you see where the A/C compressor pulley is discolored?
Apr 22, 2025 at 3:28 AM
SKOOTER28
  • 98 POSTS
Looking for hot spots.
Apr 22, 2025 at 3:29 AM
  • 55,746 POSTS
If there are hot spots that is a good sign that the compression is bad. please go over this guide to help walk you through the steps:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
And this video can help with the recharge:
https://www.youtube.com/watch?v=4EqdrBVb0sY
Please go over these guides and get back to us.
Apr 22, 2025 at 4:11 AM
