Noise from clutch area
136,000 MILES • 2.2L • 4WD • MANUAL
CONIC
This has the original clutch which is worn but still works okay. No trouble selecting any gear.
Recently started getting a rumbling noise when gears are engaged. The garage said it is the dual mass flywheel and want £1800 to repair. Other than this noise the CRV is perfect and has had regular servicing etc.
Question 1, I can put up with the rumbling but is it okay to keep driving or will something give?
Question 2, can the dual mass flywheel be replaced by a single mass flywheel?
Oct 21, 2018 at 1:35 AM
  • 55,628 POSTS
You can keep driving with the rumbling should not hurt anything. It can not be replaced with a non dual mass unit. Here is a video of the job being done on a similar car which show the process:
https://youtu.be/6N6b5F2ChyE
Cheers, Ken
Oct 22, 2018 at 5:56 AM
