Noise disappears after car warms up
25,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
NOSPAMMER
I have the LX sedan. It has been making a rattling noise since February when accelerating upon startup for first five miles-ten minutes.
It goes away after the car is warmed up. The sound is coming from the front of car (under hood or under driver/passenger side)
The sound seems like an exhaust issue but there are no codes showing nor is anything coming up with the obd2 .
I recorded video of the exhaust system with my phone and watched it on my TV monitor and did not see any signs of damage.
I am stumped as to what is going on.
Thanks
(not sure how to describe the noise. rattle?
Jun 26, 2017 at 4:43 AM
HMAC300
  • 48,601 POSTS
bang your hand against the catalytic converter if you hear noise then that may be the problem or the shield that protects the heat from the floor of car may have broken loose.
Jun 26, 2017 at 5:19 AM
  • 55,770 POSTS
Can you upload the video so we can see it?
That would really help us find the problem for you.
Cheers, Ken
Jun 26, 2017 at 11:22 AM
NOSPAMMER
I banged my hand against the catalytic converter but did not hear anything.
The video is 600 mb.
Is this definitely an exhaust matter since it's only happening when I am first driving the car until I get into third gear?
Jun 26, 2017 at 12:12 PM
HMAC300
  • 48,601 POSTS
one other thing to try is to disconnect the belt before starting then start car see if noise is still there the tension-er may be the noise so if it is you will have to change belt and tension-er to get rid of it.
Jun 26, 2017 at 10:09 PM
NOSPAMMER
Which belt are you referring to? Can you push me a link on how to do that?
Jun 27, 2017 at 3:43 AM
  • 55,770 POSTS
Hello
Here is a link to show you what Hmac300 is talking about.
https://www.2carpros.com/diagrams/ford/focus/2003
Cheers, Ken
Jun 27, 2017 at 3:52 AM
