Clacking engine noise
200,000 MILES • 0.5L • V8 • 4WD • AUTOMATIC
LADONNA AVERA
  • 6 POSTS
I had a leak where the transmission fluid goes into the cooling system. I added stop leak the leak stopped but now I have a clacking in my engine.
Nov 4, 2018 at 5:22 AM
Good morning.
Stop leak is never a good idea. It causes more issues and solves nothing. It is a band aid that will fall off and make things worse.
What fluid is leaking? Transmission or coolant?
Did you check the oil?
https://www.2carpros.com/articles/engine-noises
Nov 4, 2018 at 8:34 PM
LADONNA AVERA
  • 6 POSTS
Yes, I have good oil pressure and it has not overheated. But a closer look underneath while someone pushed on the gas it is coming from the transmission pan. Yes, I have learned my lesson about stop leak now. Could it have plugged up the transmission filter perhaps would that make a noise?
Nov 4, 2018 at 11:26 PM
Okay, you would need to replace the pan gasket. I will attach a procedure for you.
That will get most of the sealer out of the system.
Nov 4, 2018 at 11:42 PM
LADONNA AVERA
  • 6 POSTS
Thank you very much, but did I mention the leak was up where the fluid goes into the cooling system?
Nov 5, 2018 at 1:30 AM
LADONNA AVERA
  • 6 POSTS
If it matters.
Yes, but you said you used stop leak and it stopped?
Can you post a picture of what you see?
Nov 5, 2018 at 1:37 AM
LADONNA AVERA
  • 6 POSTS
I am so sorry I did not have my phone on me. I was out working on the truck, there is that really know where to get a picture it is right up by the radiator underneath the radiator hose where the transmission fluid goes into the cooling system. It is still knocking. I do not know I got to get somebody to look at it and tell me exactly where is coming from now. Thank you very much for answering and I do really appreciate it.
Nov 5, 2018 at 8:04 AM
No problem.
Yes, get someone to look at it. A leak will not cause a knock. That is a separate issue.
Let me know what they say.
Nov 5, 2018 at 8:06 AM
LADONNA AVERA
  • 6 POSTS
Okay, thanks.
Nov 5, 2018 at 8:19 AM
You are welcome.
Always glad to help.
Nov 5, 2018 at 8:21 AM
