When I accelerate there is a lot of noise
73,000 MILES • AUTOMATIC
SUZY ROBBINS
Used to do this at starting for a while then would go away when warmed up. Seems like something is stuck. Seems like it doesn’t want to go at times.
Nov 14, 2019 at 5:50 PM
Can you get a recording of this noise? This could be many things from lifter noise to spark knock but clearly without a little more info we would just be guessing. I am sure if we heard it that we would be able to narrow it down. Thanks
Nov 15, 2019 at 9:47 AM
SUZY ROBBINS
It was the clutch on the fan for the transmission cooling running all the time.
Nov 18, 2019 at 9:38 AM
Thanks for the update. I am sure that info will help others. Come back if you need something more. Thanks
Nov 18, 2019 at 9:42 AM
SUZY ROBBINS
Nov 18, 2019 at 11:20 PM
