noise
232,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TOMJJONAS
  • 10 POSTS
what is the proper for the inlet door actuator or is this the proper name thx its the one mounted on the firewall passenger side
May 21, 2023 at 2:56 AM
  • 110,248 POSTS
I believe you are referring to the recirculation door actuator. I attached a pic below that identifies all components related to the HVAC system. See if you can identify the component you are referring to. I suspect it is the recirculation door actuator.
May 21, 2023 at 1:16 PM
