Noise
200,000 MILES • 6 CYL • FWD • AUTOMATIC
MPLAIN
  • 24 POSTS
When the wheel is cranked all the way (getting out of a cramped space) and backing up there is a knocking or scrubbing kind of noise in the passenger side front.
May 27, 2017 at 12:25 PM
HMAC300
  • 48,601 POSTS
check for a loose shield and see if tire is hitting something like inner fender or suspension part. then have a mechanic check bearing on top of struts it may also be spring moving inside strut so shoot some oil to see if noise goes away or quiets down.
May 28, 2017 at 1:08 AM
