No warning lights on dash , won’t stay running
123,000 MILES • 5.7L • 4WD • AUTOMATIC
BRUCEARD21
I have a 99 gmc Yukon Denali. I turned key on and no warning lights on dash it will crank and run for 2 seconds then dies out. Checked fuses and changed fuel pump didn’t help. Any help would be greatly appreciated. Thanks
Jul 25, 2026 at 6:52 PM
  • 55,691 POSTS
You said you checked the fuses but did you check for power on both sides of the fuse? If you have a main fusible link out or there is a power supply problem at the fuse panel we need to know this first, here is a guide to help, do the test with the key on.
https://www.2carpros.com/articles/how-to-check-a-car-fuse/
Please go over this guide and get back to me.
Jul 26, 2026 at 10:49 AM
