Turn signals, brake lights, and hazard stopped working
69,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FRED ROGERS
Fuses are all good, and blinker box is good. Any help will be greatly appreciated.
Aug 30, 2021 at 10:11 AM
  • 110,248 POSTS
My primary concern is fuse 1 in the cabin fuse box. If you already checked that fuse, I need you to also check for power to it. The fuse could be good, but not getting power.
I attached the wiring schematic below for the circuit. I had to cut the pic in half to make it readable for you. I highlighted the areas of concern.
Pic 3 shows the fuses to check. Make sure there is power to and from there. If there is, then we need to check the wiring to the multi-function switch and brake light switch.
Aug 31, 2021 at 12:37 PM
FRED ROGERS
Sorry for the late reply. I will check the voltage this weekend, and let you know.
Sep 2, 2021 at 1:57 PM
FRED ROGERS
There is voltage on 1.
Sep 3, 2021 at 8:07 AM
  • 110,248 POSTS
By chance, did you also check fuse 5? It should have power with the key in the run position.
Sep 3, 2021 at 2:06 PM
FRED ROGERS
Yes, sorry, I did check #5, and it has voltage too. Thanks for reminding me.
Sep 3, 2021 at 2:27 PM
  • 110,248 POSTS
If the fuses are good and have power to and from, then we need to check for power at the brake light switch and multi-function switch. At the switches, locate the purple with an orange tracer and the white with a red tracer wires, and check for power.
If you refer to the schematic above, you'll see which ones I'm referring to.
Take care and let me know what you find. Note, we are tracing the wiring at this point to see where power is lost.
Sep 3, 2021 at 3:13 PM
