No throttle while in gear
165,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
RJONES60
My car was driving fine until it turned cold and i had problems with my battery one night and had to have a boost. After boosting the car it barely made it home. The next day it would not start and we replaced the battery. After replacing the battery, the car would start fine but when it was put in gear it would not throttle or go in either gear.
Jan 10, 2018 at 11:22 AM
  • 55,721 POSTS
It sounds like you have had a voltage spike which could have taking out a sensor. Lets start by running the codes to see if anything come up and go from there. Here is a guide to help you:
Please run this test and get back to us.
Cheers, Ken
Jan 12, 2018 at 3:46 AM
