2005 Nissan Altima Car Battery
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRFLYGUYVEGAS
My car was not turning over right after It had been started after setting awhile. I took it to check the battery. They removed it and put it on the machine and told me the battery was bad. Bad Cells. The battery is only 1.8 yrs old. I replaced the battery. No issues. I drove the car the first time and 2 miles the battery light came on and my car shut off. I coasted to a stop. I took the connections off and waited and it started again. Now it only starts after setting for awhile. Im confused on the problem? Brand new battery, but only after it sits will it start even after turning it off?
Jan 27, 2010 at 11:04 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Are you getting a check engine light on?
Mark
Jan 27, 2010 at 11:26 AM
DRFLYGUYVEGAS
The engine llight came on. When I replaced the battery it went off. Then when it went dead with the new battery, the light and the engine light came back on.
Jan 27, 2010 at 3:43 PM
  • 31,937 POSTS
Hi there,
You best start with the basics, check for spark. fuel pressure and injection pulse, run a scan and check for any unresolved fault codes, check this first.
Mark (mhpautos)
Jan 27, 2010 at 3:51 PM
DRFLYGUYVEGAS
Will run the scan. There is one thing. Right now the car will turn over only if it has set for about 15 or 30 minutes. It will not turn over if you have just turned off the car?
Jan 28, 2010 at 8:26 AM
  • 31,937 POSTS
This can be a sensor that is over heating, a scan should pick this up if this is the case.
mark
Jan 28, 2010 at 9:15 AM
