No throttle response when in gear
230,000 MILES • 6.5L • V8 • TURBO • 4WD • AUTOMATIC
WALDO92NISS
If I start my truck I can rev it up just fine everything works normal once I put it in drive or reverse I have no throttle response if you can get it Rolling about 2 miles an hour you get the throttle response back and could drive the truck down the road. But if you stop you lose throttle again until you can get it rolling and then get it back do you have any ideas what it could be
Sep 8, 2014 at 6:19 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first. I am not a diesel guy however. It may be an injector pump problem as they are known for that but aren't to hard to fix.
Sep 9, 2014 at 11:42 PM
