No Tail lights or dash lights
180,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BRYAN MARTINEZ
  • 7 POSTS
All the sudden i noticed my dash cluster or my running light were not working. My brake lights work though. If anyone can help i would be so grateful. Thanks in advance
Mar 1, 2018 at 9:49 AM
MIKE H R
  • 3,094 POSTS
would first check all the fuses, they are on two different lines for power that go into the headlight switch. the dash lights are hooked into a dimmer switch. But as I said check all the fuses. There could be a loose wire or short check the wires..
Mar 3, 2018 at 11:45 PM
BRYAN MARTINEZ
  • 7 POSTS
Got ahead of myself and was not checking both metal pieces on top of the fuse. So i did that and sure enough i found my blown fuse. I appreciate the help. thanks again.
Mar 4, 2018 at 4:32 PM
