Instrument cluster
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
LIPSTICK99
There is no tachometer reading, speedometer no indicator for what gear it is in. Seems to start out in second and shifts to third. When tachometer and speedometer does work then everything works. Just cannot get it to work.
Aug 9, 2017 at 2:03 AM
  • 55,746 POSTS
It sounds like you have a cluster that is going out, Here is a video that will help you see what you are in for when replacing it.
https://youtu.be/_HEC44xENxw
Cheers, Ken
Aug 14, 2017 at 12:56 AM
