Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Sonata
Engine
Symptoms
Not Cranking Over
No start,no crank
2002 HYUNDAI SONATA
165,000 MILES • 3.6L • 6 CYL • AUTOMATIC
KHALIFF
MEMBER
When I turn the key,my car won't start,no sounds or clicking noises,and all of the lights on the dash are illuminated
Oct 17, 2016 at 2:52 AM
CADIEMAN
Experienced Mechanic
CK. THE BATTERY VOLTAGE AND THE VOLTAGE AT THE STARTER. START HERE
Oct 17, 2016 at 4:42 AM
KHALIFF
MEMBER
No problem with battery,could it be the ignition switch or safety neutral switch?
Oct 17, 2016 at 5:49 AM
Hi KHALIFF,
It sounds like the starter is bad, the guide will show you the test that will let you know for sure.
Check the starter test portion of the guide and get back to us please.
Best, Ken
Oct 19, 2016 at 11:52 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
