no engine cranking has no check engine light and no battery light?
4,000 MILES
FRACKSON MDULAMANJA
My arvesis has no check engine light and battery and the car doesn't crank over? What can be the problem
Aug 12, 2022 at 7:50 PM
  • 55,860 POSTS
It is common for the battery to go out in colder weather. Can you turn the headlights on? Here are two guides to help tell if the battery or the battery cables are the problem:
and
Here is how to change the battery out in case you need it:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Dec 26, 2022 at 1:33 AM
