no starter action, standard corporate protocol is missing
214,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
NIGHTMAREF150
Changed the intake manifold gaskets, at first it started and ran for a minute but did not sound right so I shut it off. at restart the relay would click but starter did not turn. I replaced the starter, starter relay and ignition switch. now relay does not click and starter will not turn. I called a locksmith because the theft light on the dash is flashing rapidly. he diagnosed the SCP (standard corporate protocol) is missing there are no blown fuses and no trouble codes what can I do next?
Oct 17, 2017 at 4:04 AM
STEVE W.
  • 15,423 POSTS
That sounds like the security system tripped and it no longer recognizes your key or anything else. A dealer should be able to access the PCM and the ICM and straighten things out, but it will not be a DIY repair.
Oct 17, 2017 at 4:51 AM
