No start, spark at battery connection
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
IR472
  • 15 POSTS
New battery is arcing real bad at negative post. Previously the truck died while driving (no start no electrical).
Is this a bad alternator sign or a short?
I did find what I think are ground wires for the starter (they're running down along with the "hot" starter wire) touching the heat shield. I can not see how damaged they are but could that be it?
Nov 21, 2020 at 7:52 AM
Good evening,
Yes, it could and most likely is the issue.
I would replace both battery cables.
Nov 21, 2020 at 8:07 AM
