Hello.
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Here is the complete trouble shooting for fault p0351 and p0354
JE: Integrated Ignition Coil Pack A, B or C Failure
JE: Introduction See: Computers and Control Systems > Pinpoint Tests > JE: Integrated Ignition Coil Pack A, B or C Failure - Introduction
JE1 Determine which coil is not firing properly
Note:Electronic ignition engine timing is entirely controlled by the PCM. Electronic ignition timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
- Determine which coil is not firing properly using information from Pinpoint Test JB or DTC and the table at the beginning of this pinpoint test.
- Record cylinder, coil and PCM pin number from the table.
Have the cylinder number, coil driver and PCM pin number been recorded.
- GO to JE2.
- To obtain required information, repeat go to JE1.
JE2 DTC P0351, P0352, P0353: check ignition start/run voltage to coil pack
- Disconnect suspect coil (determined from the table).
- Key on, engine off.
- Measure voltage between ignition start/run circuit at coil pack harness connector and ground.
Is voltage greater than 10.0 volts?
- KEY OFF. GO to JE5.
- IGN START/RUN circuit fault. KEY OFF. CHECK condition of related
fuses/fuse links. If OK, REPAIR open circuit. If fuse/fuse link is damaged
CHECK IGN START/RUN circuit for short to ground. REPAIR as necessary. COMPLETE
Misfire Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles See: Computers and Control Systems > Diagnostic Trouble Code Tests and Associated Procedures > Drive Cycles
JE5 CHECK FUNCTIONALITY OF SUSPECT COIL DRIVER (CD) CIRCUIT
- Connect incandescent test lamp between IGN START/RUN and suspect CD circuit (determined from the table) at the coil pack harness connector.
- Disable fuel pump by disconnecting inertia fuel shutoff switch.
- Observe incandescent test lamp while cranking engine.
Did test lamp blink consistently?
- KEY OFF. GO to JE12.
- KEY OFF. GO to JE6.
JE6 CHECK SUSPECT CD CIRCUIT FOR OPEN IN HARNESS
- Disconnect PCM.
- Measure resistance of suspect CD circuit between PCM harness connector pin (determined from the table) and coil pack harness connector.
Is resistance less than 5 ohms?
- GO to JE7.
- REPAIR open circuit. COMPLETE Misfire Monitor Repair Verification
JE7 CHECK SUSPECT CD CIRCUIT FOR SHORT TO VPWR IN HARNESS
- Measure voltage between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is voltage less than 1.0 volt?
- KEY OFF. GO to JE8.
- KEY OFF. REPAIR short circuit. COMPLETE Misfire Monitor Repair
JE8 CHECK SUSPECT CD CIRCUIT FOR SHORT TO GROUND IN HARNESS
- Disconnect the scan tool.
- Measure resistance between suspect CD circuit at the PCM harness connector (determined from the table) and ground.
Is resistance greater than 10,000 ohms?
- REPLACE PCM. (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) See: Computers and Control Systems > Programming and Relearning > Flash Electrically Eraseable Programmable Read Only Memory - Flash EEPROM
If symptom or DTC is still present GO to GO to JE11
to check for
damaged coil, otherwise COMPLETE Misfire Monitor Repair Verification Drive
Cycle (REFER to Section 2, Drive Cycles See: Computers and Control Systems > Diagnostic Trouble Code Tests and Associated Procedures > Drive Cycles).
- REPAIR short circuit. If symptom or DTC is still present, GO to JE11
to check for damaged coil, otherwise COMPLETE Misfire Monitor
JE11 CHECK SUSPECT COIL FOR DAMAGE
- Remove spark plug wire from suspect coil tower(determined from the table).
- Connect an air gap spark tester 303-D037 (D81P-6666-A) or equivalent in series between suspect coil tower and spark plug wire.
- Observe spark tester while cranking engine.
Is the bluish-white spark present?
- KEY OFF. GO to Z1 See: Computers and Control Systems > Diagnostic Trouble Code Tests and Associated Procedures > Z: Intermittent - Pinpoint Test.
- REPLACE coil pack. COMPLETE Misfire Monitor Repair Verification
JE12 CHECK SUSPECT COIL FOR DAMAGE
- Connect an air gap spark tester 303-D037 (D81P-6666-A) or equivalent in series between suspect coil and spark plug wire.
- Reconnect coil harness connector.
Dec 29, 2020 at 4:00 AM
